Picking away at it.Got the dash done and functional.Fired it up,runs great,1st time since the tear down.Question,the top "FIN" trim clips look like the factory used some type of gasket or the putty is old, I was going to use plummers putty around the wire then push in the hole to seal,any ideas? Also where is A good source for rocker trim clips,mine are useable but are getting far from what they were after being on and off A number of times through the years(distorted/bent). Mark
Mark - I used the plumbers putty that comes in a roll with about four 3/16" strips attached to each other rather than the putty that comes in a small plastic container. Makes the job a lot easier.
Yea Matthew, it seems to me you need to post a lot of pictures from your last trip to Florida. Right????
Waiting patiently,
Everybody.
Back out in the other garage where it is supposed to be,lets hope the snow is done. Picking away at it. Working the doors upstairs in the other garage, "MY PLACE". Mark
Mark - How on earth do you keep every thing looking so neat and clean. Your car is going to be a wonder, great work. Just in case my parts car was a 59 four door and I still have three of the doors and the innards for all four. Just in case.
Putting along: Dan this is how I did the rear bumper filler,just used s/s hardware went good.Got more to clean up, and fasteners, bumper bolts to find. Did the windshield MYSELF!! It was A M O T H E R !!!!!!!!!! It was like wrestling an anaconda snake. I used tywraps in the curves and put the seam at the top, it turned out excellent !!!!!!!!!!!!!! The rear window had the track glide spot welds broken.Cleaned it up and had plenty of good space to re-tack. My table that had the trim was full and is now getting empty,it is A good thing !!!! Still got much to do. Mark P.S. last pic is how we work on them when the temp hits the upper 50's.
