Does the collar nut turn or is it welded in place? It looks like that's a stud and should just back out otherwise vice grips or a wedge of some kind should work.
It's turning with the stud as I turn the bottom nut, Dick. I'm going to try parking a nut or two between the flat side and the rear of the shroud, we'll see how that works out.
- Matthew Keij
We cut away all the material on top as we couldn't reach it with a pair of pliers. Another core support is ready to be mounted though as the old one had a lot of rust holes on the bottom
Well, mine is a little rusty, but salvageable. So, I gave the "wedge a nut in there" trick a try, and doncha know it worked!
- Matthew Keij
Matthew!! I have a special socket set for those exhaust manifold bolts on the passenger side. I don't care if we snap 'em - the manifold has been drilled out for bolts in replacement of the studs - but I could use some help. Easier to reach from topside with the radiator and shroud out of the way! I'll get from under if you hold the socket in place. Help an old man!
Two suggestions if you dont mind. On the battery tray, ospho, then encapsulator, then coat the whole tray with seamsealer, then rubber tray if you got one from Gary Goers. Keep the manifold bolts/studs soaked with pb blaster. You know l kinda miss doin that stuff. NOT!
DICK
DICK
Yup! Encapsulator before seam sealer. Then, encapsulator over the seam sealer, jut to match - it covers just fine, after the seam sealer sets up. And yes, I got the rubber tray from Gary.
I didn't know about PB Blaster. Amazon to the rescue!
I know you do, Dick! And that's why you should be going to Carlisle with us, with a stay at Chez Morton.
Wasamatteryou, didn't you see the "NOT". PB Blaster can be had at ACE and most auto parts stores.
Dick, I know you have another major project still in you! You can't blame me for trying to make it Faulkner.
So far, I've been pretty successful!
Just before Carlisle, I took my radiator to have it re-cored - and, for them to take the dent out of the top tank. The company was highly recommended. Well, they totally screwed up the tank; besides not removing the obvious dent, there's a bunch of little dents on the opposite side, and all along the side of the tank. Instead of taking a rounded block of wood, they used some pointed tool:
Because of city regulations, they can't spray high-gloss paint. But you can see the dents even with the matte finish. No way I can spray this with gloss, without it being obvious that an amateur touched it.
He's promised to make this right, even if he has to replace it. Well, we'll see.
I have a window of time tomorrow morning to drop it off before work, and since Frankford Plating is not too far from the radiator shop, I got my butt down to the basement to prepare the taillight housings.
Off to the Plater's tomorrow!
Dick! Did you mean from the back of the housing? At first, I was thinking the front - and wondering how the hell I could get a knife under that tight grommet. But I started working from the back, and don't you know, the sockets popped off, leaving the grommet. I was able to grab the lip with needle nose pliers and twist towards the center - the grommet collapsed on itself, and fell through the hole. I have brand new replacement snap-in sockets from Goers, so I just need these pix for reference.Dick Koch wrote:As far as the light sockets go find a sacrificial knife in the house, you need to pry up the lip of the socket (no easy task).
I knew - eventually - I would have to tackle the grimey, greasy front end of Faulkner. And today, I got started.
I had great ambitions of finishing the driver's side fender today, but no such luck. It was all I could do to scrape 58 years worth of caked on grime and dirt from all the front end and steering components. Now to wire brush, wipe with mineral spirits to remove the sheen, ospho and rust encapsulate.
Not sure who would have a new capacitor, it's basically just a static suppressor for the generator, to improve radio quality.
A trick I use when painting an engine compartment, is to use aluminum foil to whap around harnesses and cables, it takes a half the time as paper and tape, and does a nice job.
Ah! I remember that. There's one on the generator, too. I guess I'll confirm it's not shorted, dress the cable with heat-shrink tubing and a new terminal, and hang it back on.
Hey! That's a handy idea, for all sorts of things. Thanks for the tip, John.
Wow! great idea. And can be used over a few times.
