little by little
Re: little by little
Nice job Vic. What about mounting the compressor, did you buy the brackets or fabricate them yourself. Did you
Have to move the PS. Pump. Also would you mind sharing the make and model of the compressor.
vic barone
Post by vic barone »
Hi Dick
I had to swap the water pump for a mid 60's set up
I then purchased the brackets to suit the Sandeman 508 compressor for what basically would be a 383 set up - I then just bought them off eBay as they are a standard set up
I've also had to include a tension pulley as per the 383 set up
I've managed to keep the original ps pump as is
My belt arrangement will be as follows:
Crank -fan - tension pulley
P/s to crank
Alternator - a/c-crank
It effectively is a 68 Plymouth set up
Ive had to use an alternator with a dual pulley to make it all line up
Hope this helps
Cheers
Vic
vic barone
Whilst restoring the 59 Ive also sold my 68 Plymouth and have acquired a 57 Tbird from Dallas
She's due to be shipped tomorrow to Australia
Hope to drive this as a daily driver as the Plymouth is just too big
vic barone
Some minor updates
Wiring pretty much complete and dash installed
Wow! That's damn good looking :shock:
So clean, Vic. Puts me to shame!
Hey, how are you likin' the 'Bird? Looks sweet...
vic barone
Cheers guys
Tbird is still on the water
Due early July
Currently getting the mirror matic looked at as when I powered it up it clicks when you flash light on it but doesn't move
Found this link if anyone is interested or hasn't come across it before
http://www.ch300imp.com/mirrormatic_1959.htm
Cheers
Vic
vic barone
Hi again
An opinion if you please
Made up controls for the air freeze a/c unit to try and blend in with dash- thoughts ?
Record player - should I mount it level with floor or
Mount it at the same angle as the base of the dash
Any criticism truly welcomed- not sure if it's going over the top
Also I'm unsure how to wire up the windshield washer pump wiring to the windshield controls
The controls are variable speed and only leave two connections once you connect the motor
The foot controls have 4 connections
Any idea? Can't find the details in any of the manuals
I assume that if connected when you depress the foot pump it automatically controls the windshield wipers?
Record player level with floor
Record player inline with dash angle
Customized a/c controls
I'd say level it with the floor. Looks better.
It looks like there is too much going on when you put it in the dash angle.
I'll check on the pump when I get home
vic barone
Got my mirror back and its working
Also installed the speaker grille and ac outlets that came out of a desoto
Pretty happy with the airflow from the Vintage air unit
Ac outlets pop up and swivel
Vic - My red and white SF had factory air originally. When l restored it l checked the evaporator and have all the ventilation and AC doors vacuume system working. All l have to do is install the condenser, Sanden compressor, hoses, etc. What setup do you have for your interior AC and how will you utilize the two top dash vents.
vic barone
Hi Dick
As I didn't have a/c and my heater control was shot I opted to go after market
I ended up installing aVintageAir GenIV that has heating, cooling and demister
I have connected the 4 air outlets to the dash grilles that will be both air and heat
The unit has electric motors that regulates the air flow between air and heat
The draw back is that I've lost the glovebox as the a/c unit takes up all the space
Hallo Vic, we haven't heard from you in a while. How are things Down Under?
vic barone
Hi Dan
Yes things have been a bit slow as I’ve had to stop for a while to apese the wife an undertake renovations at Home
Hope to be back on it in the new year
On that note seasons greetings to you and your family and all the guys out there
Cheers
Vic
vic barone
Apologies Dan
Should proof read before sending
{No problem! That's what editors are for :lol: ]
