Hi evreyone! new to this, need some advice
matty
Post by matty »
How does the headlamp switch come out of the dash :? I think mines burned out, no front lghts just tailamps.
Hi Matty, I believe there's a tiny set screw in the knob itself that permits the removal of the knob (with an allen key); then you remove the bezel by turning it counterclockwise, and slide the assembly out from under the dash. But I'm speaking from memory! I could be wrong about the details.
I know that Stefan installed a relay in his car, that the headlight switch controls -- the headlight current goes through the relay, not the switch, and saves the wear and tear on the switch contacts. There might be a post in this forum somewhere about it.
So, we've seen your Belvy on eBay -- do you intend to keep it, then?
zook250
Post by zook250 »
i think on our fury there is a button that you push that has a spring under it. this releases the shaft, the shaft with the headlight knob then pulls out from the front. i found out how this works after i destroyed the shaft part, if anyone has an extra let me know. the actual switch box has a collar that you have to undo from under the dash. for reinstallation the shaft pushes back in from the front.
curt
matty
Post by matty »
Ahh sorted it now it pulls off with a good bit of effort, anyway the switch is fine turns out the dip switch is at fault :D
How areyou guys n the states? I am in the uk, i reckon theres only 3 or 4 about 4 2door ht in the uk cool eh?
Dan i am going to keep the old girl and fit a 440 in time, ilike the style not too keen on the polys performance though that said it really is great on fuel 8)
