hi beams dont work
Sorry, he only goes as far west as Pennsylvaniarogerh wrote:nope, please send Matthew..I need him to install the 4vintake the rebuilt 4vcarb, the centerlink and a few other things..
Dan Wrote:
She's a real beaut, Roger. Did you ever get to the bottom of the shock/spring issue, that has the back sitting a bit high?
I love the car!
I had a similar problem after new rear leaf springs were installed on my 59 Savoy. The car rode and sat so high it felt like an empty dump truck ride. You could not even get the car to push downin the rear with two hundred pounds of pressure on a fin!
I took it back to the spring shop and asked them to level out the car since I had already lowered the torsion bars up front. They were able to DE-ARCH the springs to a level that is just above the front ride height. There are no lowering blocks on the rear and the car rides like brand new and also carries a load without sagging since they are new springs.
Any spring shop should be able to help get the car back to a proper height.
Curt in MD
I love the car!
Curt in MD
- Matthew Keij
