window gasket?
Mark Merritt
window gasket?
Post by Mark Merritt »
Does anyone know if A gasket is available for the triangular small non-opening window behind the rear passenger doors,ahead of the rear glass? Thanks Mark
ONLY ORIGINAL ONCE!!!!!
Mark Merritt
Re: window gasket?
P.S. THE 4 DOOR SEDAN Mark
Re: window gasket?
Mark - I haven't seen any but I have a couple of used ones, I will take a look, all they need is a good soaking in Silicone. Maybe that's all yours need.
Mark Merritt
Re: window gasket?
Dick; I think I will give that A try. Doesn't look bad I will keep you in mind though. Thanks Mark
Mark Merritt
Re: window gasket?
Dick; I got out the windows, the gaskets look good, I am going to try the silicon spray, I have also read good results with soaking in ATF fluid, Mark
